Re: glass lined water heater
Posted by e-plumber on December 26, 2003 at 16:26:50:
In response to Re: glass lined water heater
: How can I tell the age of my water heater? Reply: The date of manufacture is usually in code within the serial number, on older Rheem water heaters for example, the serial number may be 0187LM7624, so this would mean the WH was made in Jan. 1987. You can always call a distributor near you or some manufacturers websites will provide this info as well. Good Luck. e-plumber
Replies to this post
There are none. |
