| Posted by LonnythePlumber on December 25, 2003 at 21:03:15: | |
| In response to Re: Tips on opening old canister typer drain trap | |
: : : : Drain from the washer is clogged- probably too much dog hair and lint. The trap is a vertical canister - looks like cast iron- with a clean out on top with the 1.5 inch square. My house is from 1921, and for all I know it hasn't been touched since then. I tried liquid wrench and a 14 inch pipe wrench, but can't budge the thing. Does anyone have any tips before I get a 3' pipe section to help the wrench out? Would heat help? Thanks. : Reply: It is best to replace the drum trap. We used to cut an X in the lead so that we could get a hand cable through the trap outlet. Then resolder closed. Some do-it-yourselfers have used electric tape. LonnythePlumber |
| There are none. |
