Re: Dishwasher Leak / Overflow
Posted by e-plumber on December 24, 2003 at 15:36:00:
In response to Re: Dishwasher Leak / Overflow
: I also have a major leak out the bottom of my Maytag Dishwasher door and it is only a week old. I am sure that the water control valve is letting to much water into the tub and does'nt stop water flow until you shut off the main water supply valve. Turning the power off to the washer should shut off the flow of water but it does not. Is there anyone else out there with similar problems? Reply: If the DW is only one week old, you should call the Maytag Man. Or, if a professional installed the unit for you, call them back and have them check it out for leaks. Good Luck & Happy Holidays. e-plumber
Replies to this post
There are none. |
