: I had my sewer line cleaned and a camera run about half way to the main (plumber said he couldn't make it go farther) Plumber said the orangeburg pipe was flattened and needed to be replaced. He could pull a new 4" line in thru the old for about $4,500 to $5,000.00 Seems high for about 150 feer? What would work cheeper. Reply: There is no such thing as "cheaper", only less expensive. You should actually get three estimates on this type of job and hopefully you had the first plumber make you a copy of the video drain piping inspection so the other two plumbers can review it. Good Luck & Happy Holidays. e-plumber
