Re: Removing Rusted Pipes/connections
Posted by S Hoxie on December 23, 2003 at 21:56:49:
In response to Re: Removing Rusted Pipes/connections
: We are replacing the pipes below our bathroom sink as they've rusted. The connection between the last pipe and the pipe in the wall has rusted so badly we cannot separate them. Any ideas of how we might do this?
: Thank you.
Welcome to the plumber's nightmare. Assume that you are dealing with the drain piping. suggest that you investigate the use of a no hub connection that could be installed by either leaving the damage piece alone or cutting off the damage and then placing the hub and tightening the hose clamp. Ask for assistance from your local plumbing supply house, they understand. Good luck
Replies to this post
There are none.
