Re: Noisy Moving Sump Pump
Posted by e-plumber on December 23, 2003 at 13:45:12:
In response to Re: Noisy Moving Sump Pump
: At the end of it's cycle my sump pump causes the piping to rattle and moves in the pit. It does have a heavy duty check valve in the discharge line. I would like to know what the possible solutions for quieting this thing down are. Heavier pump? Add flexible hose section to the piping? Buy a hand pump? Reply: If the sump pump discharge piping is next to a wall, you may need to secure the piping to help prevent movement. Good Luck & Happy Holidays. e-plumber
Replies to this post
There are none. |
