| Posted by Mr. Smith on December 21, 2003 at 23:11:16: | |
| In response to Re: Gas Pilot Light Goes Out..........a lot | |
if you have a gas meter, the meter could be bad. I have seen the gas meter not let enough gas go through it to even get the pilot lit. call you local gas company, they will be able to do a pressure test, and will replace the meter if it is bad, otherwise, it could be your thermocouple!
| There are none. |
