| Posted by jimbo on December 21, 2003 at 21:07:07: | |
| In response to Re: Moen shower control? | |
:If this is the type of Moen valve that you PULL OUT to turn on, there is NOT a temperature limit control on the valve. However, if it is a Positemp, where you just turn the valve on to cold then turn further to warm and hot, removing the handle will expose a little gizmo that looks like a gear. Arrows will explain how to adjust. |
| There are none. |
