| Posted by Deb on December 21, 2003 at 10:53:59: | |
| In response to Re: Bathtub drain frozen - Follow-up | |
: I have been reviewing some of the other posts of people having problems as well as the Price-Phister diagram. The drain is frozen in the open position and I saw the message about using WD-40. Can I remove the Overflow faceplate safely without dropping the tripwaste and bucket into the closed position? I'm a bit confused. : Thanks Generally, yes. The trip lever only raises or lowers the barrel to block the tub drain opening. |
| There are none. |
