| Posted by Daniel Terpstra on December 20, 2003 at 21:41:42: | |
| In response to Re: How Difficult is Refrigerator Water Line Hook-Up | |
I have the water line pre-run in my new home and although I'm no plumber, I do pretty well with do-it-yourself tasks. I notice, however, that my manual for the fridge does not describe how to access the water line in the back. There are lots of plastic tubes running to a covered area in the bottom so I figure I have to take it off. Is there any parts or a trick to hooking it up from there? Thanks for emailing any ideas. : : Hi, : : How difficult is it to install a Refrigerator Water : It's real easy, your local plumbing supply should have the hookup stuff, basically I would suggest using a copper line flexible and bendable purchased by the foot, along with a saddle strap gizmo which pierces into the cold water line, remember to allow enough to coil up behind the fridge so when you need to pull the fridge forward, it kinda springs uncoils etc. its real simple good luck
| There are none. |
