| Posted by Peter on December 20, 2003 at 21:22:33: | |
| In response to Re: Gas Dryer Venting | |
: : Thanks Hube. It sounds like that should solve any problems. : : : ANSWER: It still has to be vented, so it is out from the wall the amount of space the vent size takes up no matter what side its on. If on the wrong side, just run vent horizontally the width of the dryer. Hube : : FOLLOW UP: The dryer will be installed under the counter in the kitchen and if I can vent out the left side of the dryer I won't need as much space behind the dryer as I would if it vented out the back of the dryer. Therefore, I won't need a custom depth countertop.
| There are none. |
