Re: washer-dryer hook-ups in a new condo
Posted by e-plumber on December 20, 2003 at 12:50:17:
In response to Re: washer-dryer hook-ups in a new condo
: I am thinking of purchasing a condo where the previous owner has installed a washer/dryer hookup in the guest closet. He has a small combined unit sitting there right now which he says is working fine. Is this considered a "minor improvement" in the place, or is this something I should ask to see permits for, and make sure is done up to code, etc.? What should I look out for to make sure it won't give me trouble in the future? Reply: You really can't tell if it was installed according to code. The only way would be to ask to see permits (from the seller) that were pulled for the install. I have seen some installations like this that work great for years and I have seen others that were not installed properly and caused major headaches for the Condo owner. Good Luck & Happy Holidays. e-plumber
Replies to this post
There are none. |
