Re: how to adjust hot water flow on an oil burner system?
Posted by hj on December 19, 2003 at 22:55:10:
In response to Re: how to adjust hot water flow on an oil burner system?
You use less water at the sink so it stays hotter longer. Something is keeping the coil from heating the water properly. Only a service person, on site, can tell if the inside or outside of the coil is obstructed.
: Hi,
: I have a problem getting constant hot water when I shower. Where would I go to make the adjustment. Or could something else be bad or not operating correctly. All I know is that the "boiler" burns normally. We are getting heat normally but not constant hot water. The only time it gets hot is when you first initially turn it on and then it starts to get warm and then cold.. It seem that we get more hot water from the kitchen sit than the bathroom shower..
: Please help.
Replies to this post
There are none.
