Re: Replacement Toilet Tank
Posted by e-plumber on December 17, 2003 at 18:11:25:
In response to Re: Replacement Toilet Tank
: I have a cracked Toilet Tank and I was wondering if I have to replace the entire toilet or can I replace just the tank? The problem is I can't find anywhere close that carries Crane Toilets and If I did whats the odds of them having a 1991 model toilet in stock. It came with the house all I know about it is it is a Crane Plumbing product and it was made on Oct. 14, 1991. Reply: The cracked toilet tank that you have is most likely a 3.5 gallon per flush tank. Which basically means that you will need to install a complete new 1.6 GPF tank & toilet because you probably will not find what you're looking for. Consider a Toto toilet (with a 3" flush valve and fully glazed trapway) for a very strong flush if you can find one in your area. Good Luck. e-plumber
Replies to this post
There are none. |
