| Posted by Peter on December 17, 2003 at 12:20:36: | |
| In response to Re: Min. angle wye on horizontal waste line | |
My builder roughed it in horizontally. I could be wrong but I believe the check valve makes it a moot point. : What is the minimum angle a 2" inlet - on 3 x 3 x 2 wye - can have when inserting the wye into a horizontal 3" waste line above the floor? Waste water will be brought up the 2" pipe from sewage ejector. I assume it must be at least 45 degrees so other water running through the 3" pipe won't run down into the 2" pipe toward the sump basin. Can it be less than 45 degrees -- I've got some space issues.
| There are none. |
