: For about the last 2 months we have been noticing air coming out of our faucets when running water and while flushing our toilets alot of noice is present. This doesn't happen all the time when opening a faucet but happens occasionally in a days time but releaves itself after about 5 seconds. Our home is going on 19 years old and we had the wells tank and in ground pump replaced 2 years ago when our original pump went bad. I don't remember what brand of pump was put underground but I know the brand name of the tank is Well/Trol manufactured by Amtrol. Any ideas out there are appreciated. Hopefully, the PUMP is in the WELL (not in the GROUND) Check the tank pressure, it should be 2 psi below cut-in pressure when empty. Check for any leaks in the intake piping. Good luck, Hube
