Re: Shower valve location
Posted by hj on December 16, 2003 at 22:23:41:
In response to Re: Shower valve location
: Hi all,
Your question is ambiguous because we do not the direction the pipes will slant. But if I read you correctly then they can angle up to the valve and then 90 degree into it.
: Probably another stupid question. I'm installing a new fibreglass shower unit that is offset from the wall about 1 inch+. The new valve will also be an inch to inch and a half further out from the wall than the original location. Here's my question. For the supply lines to the valve, should I just just slant the lines so they run at an angle to meet the valve or should I make use of two elbows solder together halfway up the line:
: so that the lines remain straight.
: Thanks,
: Jon
Replies to this post
There are none.
