| Posted by easom on December 16, 2003 at 17:48:31: | |
| In response to Re: hissing steam radiators | |
:my steam radiators are warm at one end and cool at the other. Is this normal? : : Reply: : : The rust colored water is probably just what got stirred up while you were refilling the boiler after the piping replacement. : : The hissing noises could have been wet steam that was brought up the the rads when the boiler water level was slightly high. : Ok, thanks. Is there any way to get this wetness out of the system and stop the hissing? : : The inoperable rad could have a defective air vent, shut off valve or the piping could have sagged in the floor and is holding water preventing the steam from entering the rad. : That's great to know, I'm so glad I didn't take it apart to check, or worse yet, have it replaced. : I'm unsure as to how this type of heat actually works. When steam comes up into the radiator, does the air in the radiator escape through the air vent? Maybe that's the hissing I'm hearing. If that's how it works, why doesn't steam come out of this vent? Or am I wrong on this? Does the radiator vent each time it comes on, or is the vent only for overload/pressure safety? : Thanks again
| There are none. |
