Water pressure from shower head stops and goes and then the eventually stops
Posted by Terry Smith on December 16, 2003 at 16:59:52:
My shower consists of the type where there are three valves. The left and right valve control the hot and cold water and the center valve controls where the water comes from. The shower is fine when the water comes from the bottom faucet. However, when water comes from the shower head, the water pressure jerks and the water comes on and off. Eventually the water pressure stops. This occurs when only the hot is on, only when the cold is on, or when both hot and cold are on. I tried replacing the shower head and still the same problem occurs. So, I took off the shower head and the same problem occurs without the shower head on. What should I do? Thanks
