| Posted by e-plumber on December 16, 2003 at 14:23:44: | |
| In response to Re: Shower valve location | |
: Hi all, : Probably another stupid question. I'm installing a new fibreglass shower unit that is offset from the wall about 1 inch+. The new valve will also be an inch to inch and a half further out from the wall than the original location. Here's my question. For the supply lines to the valve, should I just just slant the lines so they run at an angle to meet the valve or should I make use of two elbows solder together halfway up the line: : || : so that the lines remain straight. : Thanks, Reply: |
| There are none. |
