Re: Plumbling and Slab Floor
Posted by James O'Dea on December 15, 2003 at 22:55:58:
In response to Re: Plumbling and Slab Floor
:Gas pipe is not allowed under a dwelling. The exception is if is in a ventilated chase, which would be difficult to accomplish . Water pipe under a slab is not a good idea. Here in Southern California, there are a number of LARGE contractors whose sole business is repiping houses due to failed copper under the slab ( also due to PB installed ). There is the issue of the freeze depth and you need some local advice on that.
Replies to this post
There are none. |
