Re: Basement Floor Leaking
Posted by Deb on December 15, 2003 at 17:27:20:
In response to Re: Basement Floor Leaking
: I'm a new home owner having trouble with the pipes under my basement floor. The problem started with water backing up from the floor drain whenever I emptied a sink, flushed a toilet, did laundry, etc. Recently, whenever a bath is emptied water comes seeping up through a network of extensive cracks in the basement's concrete floor. Am I dealing with some sort of catastrophic breakage due to pipe corrosion? If it is indeed galvanized steel that I am dealing with, than my insurance will not cover the repairs. Am I looking at something that is going to cost me an arm and a leg?
You could have a collapsed pipe under the concrete. The best plan may be to get someone to video this for you.
Deb
The Pipewench
Replies to this post
There are none.
