Re: Basement Floor Leaking
Posted by Gary Swart on December 15, 2003 at 02:56:33:
In response to Re: Basement Floor Leaking
The only thing for you to do is to get a qualified plumber on site to evaluate the problem. I suspect that you had or have a clogged drain that was backing up through the floor drain. The water coming in the cracks in the floor is possibly ground water. While I would doubt that the drain pipes are galvanized steel, that's only a guess. The cost to repair the problem will depend on what has to be done.
Replies to this post
There are none.
