Re: code question
Posted by hj on December 14, 2003 at 22:48:30:
In response to Re: code question
They all need a vent. The dimensions you are quoting is the distance the toilet can be from the vent. If the main DWV has any other fixtures tied into it above that toilet's connection it cannot be the vent for that toilet. You are either misquoting the code for your application, or misunderstanding it.
: Which code do I follow in South Dakota, IPC or UPC?
: I understand a toilet dosen't need a vent if within 12 feet of the main DWV under IPC and 6 feet under UPC. Am I wrong and why is there a difference?
Replies to this post
There are none.
