Re: lye in the toilet?
Posted by hj on December 14, 2003 at 22:45:27:
In response to Re: lye in the toilet?
Even if chemicals would work, which they will not, you would first have to know what the cause is before you would know which chemical to use. They are not generic and each has a specific application.
: We have a constant battle in my house to keep the three toilets unplugged. I know the clog is biological.... Usually plunging gets things moving, but currently we have two toilets plugged. Plunging isn't working. Should we try lye or some other chemical to help break up the clog? Is there some sort of enzyme or chemical we could use as needed to keep things moving? We are on city sewer, but is there something we could use that is used on septic systems?
Replies to this post
There are none.
