| Posted by Jim O'Dea on December 14, 2003 at 11:58:14: | |
| In response to Re: mansfield toilet flush valve | |
With ANY type of flush valve, you must ensure that the little refill tube is not pushed down inside the overflow tube. This can cause siphoning of water out of the tank. The refill tube must be held above the overflow tube using a bracket, available at supply house if if is not included with new fill valve. |
| There are none. |
