| Posted by hj on December 13, 2003 at 15:23:33: | |
| In response to Re: Accidentally cut 1/2" Polybutylene | |
It is three years too old to be eligible for a repipe. Just hope the system does not give you any major problems in the future. : Thanks for respond HJ.....the house was built in 1988. You are talking about re-piping the whole house?? Thanks! : : I use the Qest fittings when necessary. How old is the house because if it is within the guidelines I would be thinking about getting the PB replaced before your time runs out and then it fails. : : : Hi, : : : I have been doing some research and it seems like the "Qest" or "Flair-It" compression fittings would be very easy and cost effective to get the job done. : : : P.S. Should I go with the Qest or Flair-It fitting??
| There are none. |
