Re: Help - Shower valve too deep for shower handle
Posted by e-plumber on December 13, 2003 at 15:08:17:
In response to Re: Help - Shower valve too deep for shower handle
: Help. I recently remolded my shower and replaced the tile board with cultured marble. Everything was going good until I went to install the new trim. The handle hub does not seat fully with the valve stem. My problem appears to be that I did not adjust the shower valve distance when I installed the marble.
: Does Price Pfister have extended shower valve stems?
: I currently have the valve that goes with the Price Pfister 08 Series J89-975 Shower Set and replacement trim kit .
Reply:
There are extensions available to correct this problem. If the distributor or local supply house cannot assist you, call (800) Pfaucet, they will send you what you need.
Good Luck. e-plumber
Replies to this post
