| Posted by hj on December 13, 2003 at 09:07:13: | |
| In response to Re: Drill or Jackhammer the concrete of basement when installing new tub. | |
I would eliminate the "middle man" and use a sledge hammer first. You will not damage any concrete except the piece you want to remove,as long as you start where the opening is and work to the new location. : Hi, e-plumber, as I expected, you will be the first person to reply, :P. you are such a warm hearted person. : Thanks for the advise, I will use the drill first, like dig out a serious of holes and crack little by little. Renting the jackhammer will cost me $70 (a day) at homedepot which is too much for just one hole. : Again, thanks for your help!
| There are none. |
