| Posted by hj on December 13, 2003 at 09:03:34: | |
| In response to Re: Accidentally cut 1/2" Polybutylene | |
I use the Qest fittings when necessary. How old is the house because if it is within the guidelines I would be thinking about getting the PB replaced before your time runs out and then it fails. : Hi, : I have been doing some research and it seems like the "Qest" or "Flair-It" compression fittings would be very easy and cost effective to get the job done. : P.S. Should I go with the Qest or Flair-It fitting??
