Re: Is gate valve necessary in sewage ejector discharge pipe?
Posted by Deb on December 13, 2003 at 01:17:15:
In response to Re: Is gate valve necessary in sewage ejector discharge pipe?
: I'm installing a sewage ejector. I've got a check valve that will pass 2" solids. I've seen in drawings that a gate or ball valve should be inserted above the check valve. Is this necessary? Will it typically still pass code without it? Any thoughts are appreciated. UPC requires a gate valve. Deb The Pipewench
Replies to this post
There are none. |
