| Posted by Bob O'Donnell on December 13, 2003 at 01:04:04: | |
| In response to Re: Hot Water Leak in Concrete Slab | |
I have multiple leaks. Re-plumb. I hired a leak detection company. They can only get close. I have radiant heat -so, in the process of reaching the copper pipe they will destroy some elements of the radiant heat tubing. I'll use copper for the new lines in the space between the first and second floors. It's easy to work with and copper isn't that expensive. Plumbers are of course. Might do it myself. Only one bid received from a plumber they want $4000. Figure I can do it for less than $100. Good luck.
: Thanks in advance for you help ! : Jeff..
| There are none. |
