| Posted by hj on December 12, 2003 at 21:49:33: | |
| In response to Re: Is gate valve necessary in sewage ejector discharge pipe? | |
I have never installed a gate, or ball, valve on sn ejector discharge unless it was a two pump system. : I'm installing a sewage ejector. I've got a check valve that will pass 2" solids. I've seen in drawings that a gate or ball valve should be inserted above the check valve. Is this necessary? Will it typically still pass code without it? Any thoughts are appreciated.
| There are none. |
