Re: PVC to cast iron transition fitting
Posted by DIYGreg on December 12, 2003 at 19:40:48:
In response to Re: PVC to cast iron transition fitting
Just wanted to clarify. The clean out plug is horizontal in a vertical cast iron T at the base of the main stack/foundation as it increases to 4" sewer main. There is nothing more to melt out - it's one piece. The plug is 3 1/2". I purchased a 3 1/2" to 3" threaded bushing, and plan on using this and then a 3" Y to connect the branch drain. Am I missing anything here? Thanks for all your help!
Replies to this post
There are none. |
