Tub Drain
Posted by Leslie on December 12, 2003 at 18:04:51:
We are building a "cold tub" to go with a sauna. It is built into a tile deck indoors. The plumber can't find an inline drain the isn't a tip type drain. I would like a lever on the top or side of the deck that would close the line as it passes out to the stack.
Do you know of any way to do this?
I have tried to draw it here: The level stops the drain in a pipe that runs under it. The pipes will be 1 1/2 and 2 inch pipes.
Lever ---| )
| | Drain
_________| [] |_______________| |
___________[]______________________|
Replies to this post
There are none.
