| Posted by jeff cole on December 12, 2003 at 17:07:36: | |
I am having a problem with very low water volume is more than one faucet is opened the second has hardley any flow at all. My pressure switch is set to a cut on at approximately 30 lbs and off at aproximately 50 pounds of pressure. My pump is a 3/4 hp submersible at approximately 140 feet and the static water level in the well is approximately 30 feet. I have a 2 story house and there is little difference on the secod floor. Any ideas? also should the air pressure in the tank be set with the tank empty or at pressure? |
