| Posted by Tim on December 12, 2003 at 12:51:59: | |
| In response to Re: Shower drain connection | |
: : I'm nearing completion of my shower installation (thanks for all the help with previous questions!). I'm working on connecting the shower drain to the stub-out. I have one of those Oatey drain assemblies with the rubber gasket that fits between the drain assembly and the stub-out. My problem is that the stub-out should be perfectly vertical (according to the instructions) but, due to the necessary pitch of the drain line, the stub-out is at an angle. : : This must be a common problem, what is the best way to deal with it? Just force the gasket around the stub-out? : : Thanks, : Reply:
Barring that, is there a trick to cementing the stub-out into the p-trap to compensate for the pitch of the waste line? Thanks again, |
