| Posted by e-plumber on December 12, 2003 at 12:28:35: | |
| In response to Re: Is gate valve necessary in sewage ejector discharge pipe? | |
![]() : I'm installing a sewage ejector. I've got a check valve that will pass 2" solids. I've seen in drawings that a gate or ball valve should be inserted above the check valve. Is this necessary? Will it typically still pass code without it? Any thoughts are appreciated. Reply: |
| There are none. |
