| Posted by nicktheplumber on December 11, 2003 at 21:21:48: | |
| In response to Re: Another vent question . . . | |
Steve, Technically, you are "wet-venting" the lav, but it looks as if you have laid out the DWV pipes for good drainage. If there is nothing else except the lav draining into the shower/bath vent, your setup should work. It is OK to wet-vent a lav, but other fixtures with more drainage would not be OK. |
| There are none. |
