Re: Insulating Shower Pipes
Posted by e-plumber on December 11, 2003 at 17:53:17:
In response to Re: Insulating Shower Pipes
: Hi e-plumber : Thanks for the help! Do you think that a higher flow head would cause the water temp to be hotter? : Thanks : Jim: : : Hello : : : Great site! The hot water to my master shower take about two minutes to heat and does not get very hot(sits about 30 feet from a new hot water heater). The second bath, which is right next to the hot water heater, heats up quickly and gets very hot. I know that the second bath's pipes are insulated (wrapped all around the valve and 2 feet down the pipe). Do you think that insulating the master bath pipes would greatly help or is it just too far from the water heater? : : : Thanks for any help. : : : Jim : : Reply: : : Insulating piping is a good thing but I doubt it will help in your case. The distance away from the water heater and the low flow shower head is most likely the cause of the problem. : : Good Luck. e-plumber Reply: No, but if it's a flow restriction problem, increasing the flow rate at the showerhead will draw the water faster from the WH. e-plumber
Replies to this post
There are none. |
