| Posted by jim on December 11, 2003 at 14:08:50: | |
| In response to Re: Insulating Shower Pipes | |
Hi Deb Thanks for the help! So, do you think that, if my water pressure was higher, that the water temp would get hotter. That makes sense since it seems like low pressure might cause a backlog of cooler water. Thanks : : Hello : : Thanks for any help. : You might check to see if there is a device under the handle that limits the amount the hot water will turn on. It is a safety feature on many newer valves and is adjustable.
