| Posted by h on December 11, 2003 at 08:27:19: | |
| In response to Re: leaking ball valve | |
Probably not unless the leak is from the packing under the handle, which can be tightened after removing the handle. : I recently tried shutting a ball valve and notice that there is a small amount of water that is leaking from the valve. Is there a way of adjusting the valve to stop the leak?
| There are none. |
