| Posted by Denis on December 11, 2003 at 07:59:30: | |
| In response to Re: Amtrol wired for priority? | |
: : I had a new furnace and Amtrol hot water heater installed a little over a year ago. The setup is controlled by a TACO 6 zone controller with the zone 6 priority option. : : The Amtrol is currently wired so that the heating zones can demand at the same time as the hot water which can be a bad combination if a couple of heating zones start demanding right when someone is taking a shower. Zone 6 is available so I would like to rewire the Amtrol to zone 6 but cannot find instructions or a diagram. I have the TACO diagram and am somewhat familiar with zone contollers but not with the indirect hot water heater wiring. : : Has anyone out there done this? : : Thanks... : : Does anyone have any : Reply: Thanks e-plumber. I've since found the manual for the Amtrol unit. I checked the wiring and it is wired in "without priority" mode. I'll give the installed a call. |
| There are none. |
