| Posted by Deb on December 09, 2003 at 18:39:07: | |
| In response to Re: Any tips on inserting wye into drain line? | |
: I'm adding a sewage ejector and need to pump the waste through 2" pipe into the current 3" portion of a drain line overhead. For this, I need to insert a wye into the current pipe. I don't think there will be much flexibility for moving the two ends of the pipes once they're cut. : What is the best way to handle inserting the wye? Use no hub couplings. |
