| Posted by Hube on December 09, 2003 at 13:10:30: | |
| In response to Re: Pressure Tanks | |
: I was told to drain down the pressure tank and bring the air pressure upto 2 lbs. below low setting. I have an air pump that will fill a car tire from flat to 32 psi in about 15 minutes... : I ran the pump for about 5 minutes, and it barely changed from 12 to 15 psi. Do I just need to be patient, or is something else wrong? : Thank you again! |
| There are none. |
