Re: Running gas line down chimney flue for gas log install
Posted by Deb on December 09, 2003 at 11:17:11:
In response to Re: Running gas line down chimney flue for gas log install
: I am installing vent-free gas logs into a fireplace in the basement of my house. The only way to get the gas to the logset is to go down the chimney flue. Local gas company said that was okay.. Installed using the CSST that has a plastic jacket around it. When logs are on, the CSST is getting hot. The website for the CSST (gastite.com) said that the jacket was rated to 200F and the tubing to 2400F. If I strip the jacket off the tubing, do you think it will be okay to leave it installed as is? I think after the tubing gets out of the firebox and into the flue, there will be enough fresh air to keep the tubing from getting too hot. If you decide to keep this installation, can I get a life insurance policy on you with me as beneficiary????? This is such a bad idea that I cannot believe anyone would ever consider it... Deb The Pipewench
Replies to this post
There are none. |
