| Posted by HJ on December 09, 2003 at 08:03:44: | |
| In response to Re: Leaky Solder Joint / Unbalanced Main Water Makeup | |
Once water gets into a leaking joint, the flux is washed away and the copper surface becomes contaminated. For that reason, reheating and applying solder will merely cover the surface of the joint, and the solder will not flow into the joint to make a proper seal. : I redid my main outside plumbing area just before the line goes into the house and : Also, on one end of the assembly there is a regulator and as a result,
| There are none. |
