| Posted by Paul F. on December 09, 2003 at 06:04:21: | |
| In response to Re: New toliet flange | |
: Yes, the flange must be solidly attached to the closet bend. Use PVC cement for PVC fittings or ABS solvent for ABS fittings. If you have cast iron, then the proper hub for attaching the flange is required. The flange should set on top of the finished floor and be screwed through the finished floor into the subfloor.
| There are none. |
