| Posted by Michael Roback on December 09, 2003 at 01:34:55: | |
I redid my main outside plumbing area just before the line goes into the house and also ties into an irrigation line. I had two regulators and two ball valves. Problem is when I fired it up, the connection into the house and an ajoining 90 are leaking. If I have to remove them and resweat, I will have to take half of my assembly apart. Are there any tricks to repair a leaking connection. Would reheating and applying some solder around the joint help??? Also, on one end of the assembly there is a regulator and as a result,
