| Posted by John Bridge on December 08, 2003 at 23:50:25: | |
| In response to Re: Glass Block Question | |
![]() Hi Nicole, You'll need to install your shower pan liner over the curb (lip?) before you begin laying up your blocks. Building a ceramic tile shower is quite a process. I don't think Terry and the folks here will mind if I re-route you to our forums. We deal in nothing but tile and stone work. I'll leave a link below. :-) John : We are converting a tub area to a walk in shower (which will be the same size as the original tub space). We would like the wall facing the bathroom to be a glass block 1/2 wall (approx. 4" high) with a small space to walk in on the end away from the shower head. (no door). : Our question is what type of base do we need to use for the glass block wall. Right now we have a simple shower lip with 2 pre-treated 2X4's stacked on top of each other. Can we begin stacking the blocks on top of this base or do we need something wider? : Also - we don't want a wooden frame at the top of the wall if possible so it is simply a glass line. Is this possible or do we need to frame the wall in to have enough support? : Any help you can give will be great! Thanks. |
| There are none. |
